Lock Rite VS Spartan locker
Thank you, 4.10s
Good choice for any final Transmission ratio that's 1:1.
I've been running Lockrites front and rear for almost 20 years now. From 33's on up to 36's and they have performed flawlessly.
The biggest factor with these, as I suspect most lunchbox lockers, is case tolerance. If you even suspect your case is worn, don't do a full install without first checking the tolerance. .001 for Lockrites if I remember correctly.
