LSD opinions? Yukon, Auburn, Eaton?
Kane
Full Time Jeeper
- Media
- 4
- Berlin, CT
- 1984 CJ-8 Restomod Scout axles 4 wheel disks, 258, ax15, D300.
I am rebuilding a set of Dana 44 axles froma scout and I finished the front last week. I just finished cleaning the housing on the rear and was taking apart the carrier when I found the drive pin and spiders are shot. I found significant wear on the case as well where the thrust washers sat. So know I have a choice. I was considering dropping in a locker of some sort but I only want a selectable for the better street manners. Those are more than I want to spend at this point and the Jeep will not be a hard core offroad vehicle. I am not sure at this time how much it will see dirt. So my other option would be a good LSD and then I can drop in a lunch box locker for the front end since I have the twin stick for the Dana 300 this makes good sense to me.
So I read allot about the Truetrac from Eaton but they do not recommend tall tires and many people have blown them up due to the amount of small moving parts. The stock replacements like the Track lock are not an option as they are not very good. I had one before in a CJ7 . So what about the rest? Auburn has a cheap one but it is not rebuildable. Yukon makes the Powerlock I think. Anyone have good experience with the aftermarket LSD unit?
If I have to I may go to the Ziplocker from Yukon but $750 is a hard number to swallow on something that will see Limited offroad use.
, you did too. Good score! That's a value meal at Mcdees!
