More Quadtrac Questions (Output shaft movement?)
tthstrm179
CA
1978 CJ7 304, Th400, Quadra trac converted to part time and low range
I have a 1978 CJ7 with the AMC 304 and Quadractrac/GM Turbo 400 . I have posted several questions as I work on this system since it is not familiar to me.
Recently I changed the Transfer Case chain which seemed straight forward. While the case was apart, I changed the seal on the rear output shaft.
Yesterday I found that the seal was leaking and removed the yoke to find the seal leaking. It looked like I had not set it deep enough and it was getting chewed up from the yoke sitting too close to it.
QUESTION:
I noticed that the output shaft can move in and out about 1", maybe more. I did not take it out or remove the snap ring from the bearing in it. I know it is sliding back and forth in the primary gear within the case, but is this normal? Wondering if i messed something up.
QUESTION:
Any advice on the seal? I had it driven in flush with the case on the last one.
Thank you!
Figured this one out. Sometimes the answer is the obvious one. The yoke was not seated all of the way down on the splines. It had hung up even though I torqued it down. This was allowed the shafted to slide in and out since the yoke keeps it tight, and the movement killed the seal. But I do have another issue, and the case is again apart. Posting under a new thread.
    Best for votes
    on specific items
