Moser 1 piece axle problems
ColeTrickle
- Fort Worth
- '83 CJ7 Laredo 258/T5/D300
'80 J10 Honcho 360/727/NP208,
'79 J10 Honcho 360/TH400/QT,
'75 J20 "Workhorse" 360/T18/D20
I've searched, listened and thought it was my drums rattling. I was WRONG!
The sound is similar to a rock in a hub cap.
Unfortunately,
I've come to the conclusion that the noise is coming from the axle being able to move ever so slightly in the housing...only while a 33" tire is connected.
The movement is only around 1/8-3/16" of an inch on the tip of the tire. Not in and out, just a up and down movement at 12, 3, 6, & 9 o'clock positions.
There is hardly if any physical movement after install of the axle and completing the install of the drum (I've got to this point several times and cannot get movement).
The first call I had with Moser, I was told to basically do the install over again. Check the .02-.08" space in the bearing. Well, since I didn't want to take the pressed off bearing off. I went to O'Reilly's and got a Federal Mogul bearing and mocked it up checking the tolerances. Everything was in spec with this bearing in the housing. Granted it wasn't a Timken but the tolerances of the 2 cannot be that far apart to cause this noise.
Second call to Moser, I was told that my housing ends could be ovalized causing the bearing spacer ring not to seat properly. I asked, "so both sides are bad?"
Then I was told well your bearing is sandwiched with the backing plate so maybe your race is to far in and you may need to space your bearing spacer ring. WTF!?!
I apologize for the long wind. I figured I would have had this figured out by now. I got a 2000 mile round trip journey in this thing in a month and am starting to sweat.
Last question...could the bearing act as a fulcrum and my carrier has the "Play"?
Thank you for any and all opinions!!!
Unfortunately,
