My Blazer Heater Blower Motor Upgrade
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
Honda vtx1800c
Thanks for the pics Guy. I am going to perform this mod to my '86 CJ7 as I have to change out the heater core that shot craps on me the day after I bought the rig.
One question, seeing what you went through with the hole saw, how much trouble would it be to use a die grinder to enlarge the hole? I was considering using a rotary file and running the circumference of the hole until it was large enough to accept the new motor.
Keep up the good work........
Well they let me return the hole saw so the whole project only ran me the cost of the motor so that made me less angry. To be honest if you found a stronger piece of wood and a hole saw with a longer bit, and used a variable speed drill I think you will have less trouble. Assuming you can get in there with your die grinder easily then sure that would be easy to do and is one of the suggested methods. However you are not likely to end up with a circular hole if you do it by hand that way. I know I am one to talk considering my hole isn't a perfect circle but if I had used the dremel I know I would have done worse....
You did pretty good Thisguyuknow remember it gets hidden by the battery tray...Trapshooter I also have performed this mod I did the rotary file method it worked fine for me I think its a matter of prefrence which way do you feel more comfortable doing :chug:
Yeah I know when I put something to seal the firewall you wont even notice. I just like my mods to look like they were stock is all:chug:
Any chance you could post the motor part number? My heater box is out so i may as well do the mod!!!:chug:
Sure. Just tel the zone monkey that you need a blower from a 73 blazer with ac. I will get you the siemens part number stamped on it in the morning. You know my motor still works if you want it.
I appreciate the offer but mine still runs too, just want the upgrade,,,,,northern Ohio winters! :)
Here is a very good write up on the mod:
Jeep Heater Blower Motor Upgrade
I purchased my motor at Auotzone using P/N PM102 for about $20. Bring a tape measure with you and make sure the shaft is 1 3/16" to the end of the threads.
There is another motor for the Chevy Blazer family with a longer shaft ( PM105, 1 13/16" shaft) that will not work. I've read stories about some people running into the wrong part in the correct box.
I have yet to install this mod myself even though I have all the parts. I have to replace my heater core at the same time. Its going to take me a little longer as I have to remove the roll cage and pull the factory A/C unit to get behind the dash. I will most likely wait until later this summer.
Hope this helps......
I need to do this. I'm sure the fan will probably go out one of these days. I've already replaced the core.
Is your ac unit still working? If not just disconect the two hoses(one at the compressor and one at the can thing,condensor?) and slide them through your firewall. It will only be two or three screws holding your ac to the dash drops right out once you disconnect the ground and the hot lead to it.
Guy,
Thanks for the tip on dropping the A/C. The system blows air but the compressor clutch will not engage. The PO told me it was hooked up but I don't think he really knew for sure. Looking the system over I believe it still has the orginal receiver/dryer.
Guy,
Well the question is do you have freon In the system or did it leak out?? My system was dry so I removes it the way I said.
I did this upgrade today while replacing the heater core. In addition to the PM102 part number for most auto parts stores, if you go to Napa Auto Parts, their number is BK 6551039 (you do not want BK 6551076). I was able to do it without removing the dash (though it would have been easier if I had). I also made the hole larger with careful use of tin snips.
i have done this to. throws alot more heat out :D
I did this mod years ago, but instead of the Blazer motor, I used one from a '73 Suburban with A/C...Napa part #7135587.
Other then the usual widening of the firewall access, it was a direct swap with the stock squirrel cage. No shaft modification or anything.
Even on low this thing rocks. It moves so much air, that the high setting only pushes marginal heat due to the volume moving past the core.
