Mystery clamp and hose
Colo Dean
Greeley Co
74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
Thanks, may work on replacing the charcoal canister down the road. Since its registered as a classic, there are no visual or smog tests that I have to do. Will look into hooking up the red hoses back to the fuel tank once I figure out what the PO did to plug the tank.
On a side note, I noticed on the passenger frame rail, the fuel line is mostly plastic until it gets to the fuel pump. Was this common to use plastic fuel line then or something else the PO did?
I have never worked on one as old as yours but on the newer ones they had a hard line running from the tank to the pump and I would bet that is how yours should be.
Kinda thought so, looks like anther reason to hit the parts store. Not sure I like the idea of plastic line and fuel together.
Those red tubes look. Pretty familiar. I m pretty sure that was stock.
Those charcoal cans are pretty expensive now and were a poor attempt to help emissions. :D
The check and rollover are worth hooking up.
Thanks, may just watch for a canister at a salvage yard and hook up the rest for now.
OEM would have been steel and rubber.
Simply: The rollover and check valves prevent liquid gasoline from being sucked into the charcoal canister. In the event of a rollover or 'flop' onto the driver's side, without the check valve, the engine may run long enough to provide vacuum and instead of drawing fumes it would draw liquid.
Preventing liquid gasoline from running out of the tank would rely on the gas cap seal and the seal where the sending/pickup unit inserts into the tank. Without a good seal on these parts (and filler/vent hoses), gasoline will still spill and present a fire hazard.
My CJ had Green Plastic lines on parts of the return line and to the roll over valves. Must be a trend! ;) Rod
If I reconnect the check/rollover valves should I plug the line going to the canister until I locate one? Or is this not an issue since without the canister there wont be a vacuum being drawn on that part of the system.
