Need help to identify my oil sending unit
danray48
NE Ohio
79 Jeep CJ7, 258 T150, Dana 20 soon to be T176, Dana 300
While wiring my centech harness, I wired my oil pressure gauge according to the wiring directions, and that part is ok. My existing oil sending unit has a place on it for a oil line, but it was solderd shut. The sending unit is a one wire slide on connector, (my gauge does not have a place for a oil line) I wanted a new sending unit, so I ordered one from Morris, for a 79 AMC 258 i6 / 4.2l motor. The one I got is a three prong unit. My wiring harness came with one wire marked "oil". My question is, Is the three prong unit for a mechanical gauge, or the one wire unit? I should clarify, that the old sending unit is screwed in and not part of the brass fitting that has the solderd oil line. Am I making sense? The main question, is does a mechanical oil pressure unit have a 3 prong or a 1 prong connection. I just thought the 3 prong would be for reading resistence. My wiring diagram does not specify which one......Thanks
A mechanical gage will only have a fitting. Like 1/4 NPT.
Pretty sure your stock gage was electrical - one big cluster.
Are you running stock or aftermarket Gage's?
Pics really help too. :D
Well, there is a oil pressure sender switch, and a oil pressure switch. The three prong one has a switch for the electric choke, and one terminal for the gauge. The gauge switch only tells you if you have oil pressure or not, not how much oil pressure. I bought a replacement for my 1980 from NAPA and used air pressure to tell if it was a switch or actually would tell how much pressure I had. It was a switch. Yep, big can with one terminal on top. I finally gave up and got a gauge and sender from Auto Meter.
And yes, mechanical senders do not have electrical connectors.
There's a light? Forgot about that. Some of those big cans are also switches that just tell you that you have oil pressure. Like GM loves to do.
I think it's a stock gauge
