Electrical Need Mini-starter advice
Oldguyinajeep
Derby, KS
'86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
My CJ has always had a horrible grinding when I start it. It actually turns heads when there are people around. I've replaced bendixes and starters to no avail. Last winter, when I replaced the clutch, I replaced the ring gear, starter, AND bell housing. Same noise. Very frustrating. I was telling the story to a mechanic today, and he suggested a mini starter as the solution. Apparently AMC had a lot of issues with this and, unlike other manufacturers setups, shims cannot be used to correct the depth of the starter gear relative to the ring gear. He said a mini starter, with its adjustability could solve the problem.
I'd like to know if anyone else here has had this problem, and if a mini starter was used as a solution. Also, I'd like to know of any particular brand of mini starter that any of you would suggest. Any help is much appreciated.
:popcorn:
First, I want to start off by saying that I don't claim to be an expert in what your issue is...I can only relate to my own experience with a completely different motor.
Last fall, I built and swapped in a 351w into my CJ5 . Those engines have two different starter options based on the rest of the drivetrain...one for manuals, and one for automatics due to the different depths for flywheel/flexplate. Even though I knew that, I still accidentally ordered the wrong starter and the starter gear would only engage maybe 20% into the flywheel and it would grind like crazy. Once I installed the correct starter, it worked just fine.
Maybe the same issue...
And in my experience with Chevy engines, the old big and heavy starters are inherently much noisier compared to modern mini starters that are equipped with torque assisted gear reduction feature.
First of all, thanks for your replies. I've scoured the net for mini starters that might solve the problem. Nothing. I do most of my own mechanical work, but the really challenging stuff goes to a local guy who was a general mechanic for a thousand years, but whose real love was in racing. He deals mainly in performance stuff now, in his waning working years. He likes a challenge. He called a number of manufacturers, and got some good info from PowerMaster.
The solution is complex. Some engines, bell housings, and trannys don't always line up properly (apparently a common problem when racing small block chevys). They have to be lined up using precision instruments and offset dowels on the bell housing. It's not as big of a deal with the engine on a stand, and my guy has done it many times, but is a pain in the <-BAD WORD-> in the vehicle. So... he'll be dropping the tranny and Transfer Case to do the alignment. There is a chance that this won't fix the problem, but it's the only option I have. I'll report back after the work is done. Thanks again for your responses.
