Need some review on my wiring schematic
jmoreau002
pville, la
I new here and I believe this is my first post. Im trying to restore an ole 55 CJ5 . It was a rust bucket when I picked it up and many of the ancillary components were trashed or missing out right. I've begun to collect all the components and plan out the wiring. Attached is a spreadsheet that I compiled for myself.
Im stuck on a few circuits and am having some trouble following some of the old schematics in the Haynes manual. Specifically:
  1. The externally mounted starter solenoid has 2 small terminals. I know one of them is connected to key witch START terminal to open the current to the starter, but where does the other go?
  2. Does my planned Dummy Light wiring appear correct?
  3. The key switch itself has 4 positions: Key in. Left to ACC, Key in to OFF, Key in Right to IGN, and spring return START. Likewise on the back of the switch, I have BATT, IGN, ACC, START. Are my current connections correct on here?
  4. Anything else that you see, please let me know.
Keep in mind that I have not begun to wire lights and accessories yet. Im just concerned about my progress so far...the engine electrical and gauges.
Thanks guys.:chug:
I new here and I believe this is my first post. Im trying to restore an ole 55 CJ5. It was a rust bucket when I picked it up and many of the ancillary components were trashed or missing out right. I've begun to collect all the components and plan out the wiring. Attached is a spreadsheet that I compiled for myself.
Thanks guys.:chug:
1. The second post is for the ACC on. You dont really need it. It is mostly used as a post to supply power to auxiliary systems that need 12v in the on position. If you have nothing to hook up there you can not worry about it.
The rest I dont know I cant open your file
looks pretty good to me but I dont have a wiring diagram to compare to. I dont see anything that would keep that from working.
The brown wire for the indicator light coming off the alternator is grounded when the alternator is not charging and provides +12V when it is charging. This wire goes to one side of the lamp. The other side of the lamp is hooked up to +12V battery power when the key is on in IGN. When the alternator is not charging, the lamp gets the +12V from the battery and ground from the alternator, so the lamp comes on. Once the alternator starts charging the lamp now has +12V on both terminals, so it goes out.
As far as the open terminal on the solenoid, gert says to ground it and thisguyuknow says it supplies 12v for accessories, and busadave says it goes to the positive terminal on the ignition coil .
Now Im confused.
Now Im confused.
my apologies if i confused you, I looked at my schematic again and the 14B LT BLUE 16 goes from the starter relay to the neutral starter safety switch for automatics and has a jumper in the connector to bypass it for manual trannys it then turns into wire 14A LIGHT BLUE 16 which goes to the ignition switch. It has been awhile since I wired mine, I am the one who is confused I thought that was the stud that I grounded so that my solenoid would activate the starter circuit. When I rewired my Jeep I used the Painless 10110 jeep wire harness using mostly the painless manual and referencing the factory manual.
