No oil pressure
Rj67cj6
- Houma, Louisiana
- 97' Wrangler-given to son
79' CJ5-sold, but not forgotten
05' LJ-DD, but will be 4 son#2
67' CJ6-work in progress
I have a mechanical oil pressure gauge. I've started the jeep up several times and let idle for several minutes, but I'm getting no oil pressure readings.
It is the 225 V6. The oil pump was inspected and packed with petroleum jelly when the engine was out of the jeep.
Is there any other way to check to make sure he oil pump is working? If the petroleum jelly trick didn't work, Is there any other way to prime the pump?
The tube used for the oil pressure gauge does have oil in it, however, it has air pockets in it.
Thanks in advance
Thanks in advance
