Oil Change Frequency Question?
I use 10% STP in my knuckle pudding mixture, oh wait, that's in my D25 and this thread is about motor oil. Never mind. :D
Posi
Just get a tub of CV-joint grease. ;)
That would work as well. I use axle grease and STP.
Main bearings are not made of brass.;)
http://kingbearings.com/files/Engine_Bearing_Materials.pdf
I was referring to the oil stabilizer. I have not heard of the magnum oil.
STP oil treatment was around long before Lucas. I use it as an assembly lube when building an engine or gear box or diff.
There was a chart that compared the the two. I can't find it now.:(
I said brass and was thinking copper. Nonetheless it wasn't present in this case.
I just filled this summer with Rotella 15-40 - thoughts on that stuff?
Wooly
Rotella is a good oil and it has the zinc that's good for the old engines.
    Best for votes
    on specific items
Engine Oil
