    Thank you for your support!
oil leak?
Fuel pump gasket or the actual fuel pump. I have seen the fuel pump pivot actually wear a hole into the aluminum housing causing a leak.
Can be casued by many things, heat, how old it is etc. You just gotta handle it appropriately or else you will be like me and not notice untill you spend loads in fuel, you have just got to be careful i guess.
