Oil pressure switch
Oil pressure switch
b3uhbp
Arlington, TX
84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
Hello all. Yesterday my oil pressure gauge dropped to zero then came back up but was very erratic and showing very low pressure. There was plenty of oil in the crank case so I was pretty sure the oil sending unit or pressure switch were bad so I replaced them both. Everything seemed fine, showing 55lbs psi, higher than I had ever seen on this jeep, and the needle was holding very steady. Then all of a sudden the needle became erratic. What’s going on? I’m clueless on this one.
You could add in a mechanical oil pressure gauge by teeing into the existing oil pressure sending unit. From there you could research out the electric gauge problem. The oil pressure send unit and gauge both require grounds, make sure those are hooked up. From there it could be a bad wire or send unit.
Good advice. I’ll check all wiring and see what happens. The odd thing is that it was working so well initially. Even though it is unlikely I did replace the sending unit. Also, the two blade plug that’s at at 90 degrees to the sending unit, what does it do? I’m. Pretty sure it is just a switch but for what? There’s no idiot light on these old cjs. Did it work with the old computer in some way?
b3uhbp, that two bladed plug is some sort of oil pressure switch that is tied into the computer. In a wiring diagram for my '86, it has a red and red w/tracer wires on it.
It wouldn't hurt for you to run a dedicated GND lead from the dash panel to the NEG(-)battery post.
That’s a great idea and easy. I will get that done. Thanks
I promised to provide an update so here it is. The oil pressure gauge is working perfectly. I replaced the original connector with an eyelet and secured it with the nut on top of the sender. Nice steady needle showing 20lbs at idle and 40lbs at cruise speed. Pretty sure it as a grounding issue. Thanks all.
Engine Oil
