Oil pump replacement buy with new tube or use old
Techlight
California desert
1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Hi All,
I'm about to put a new re-manufactured engine in my 84 CJ7 and figured I'd replace the oil pump while i'm there.
Do I need any special tools to attach the tube and screen to the pump? I can buy a Melling pump only for about 60 bucks. The pump and tube/screen is about 160 so I was hoping to use the old tube and screen.
Any advice? Should I just buy the pump/screen/tube new or reuse tube/screen?
Thanks.
The pickup tube can be a royal pain to swap. Heat the old pump to remove.
That said the new one might not come installed so your in the same situation.
You can make a tube driver by cutting a piece of pipe off at an angle or buy the tool for it.
Either way you need to take a reference measurement to the bottom of oil pan subtract 3/8-1/2” and install the new pump on the engine set the pickup tube to that height reference mark the angle then take the pump off and install the tube- don’t try to beat it on installed in the block.
Once pickup tube is installed tape a 3/8-1/2” drill bit to the screen couple dabs of grease and set the pan down to check for clearance.
I did a new Melling, didn't come with tube installed -pain. Wished it had. Get new tube - doable
Thanks for the replies...I ended up ordering all new. I'll look into making that tool or having my local shop do it for me maybe.
