    Thank you for your support!
One piece rear main seal?
projectcrawler
clayton, DE
78 CJ7
While the motor and Transmission are out, I'm going to fix the leaks. Anyone know of a company who makes or sells a one piece rear main? Or any other tips so I don't have to seal again for a while. Never trusted the 2 piece style.:(
I don't think I have ever seen a direct one piece replacement seal for a two piece anywhere. To do that little trick I don't see anyway you would be able to pull that off without machining the block and the main cap.
Unaware of one, but ask my little CJ maybe he knows. I know what you mean about the 2 pc. It's a leap of faith every time I do one! I don't know if there is anything worse than getting the whole mess buttoned up only to see that little drip of oil come back in a day!:mad:
I havent had to mess with mine yet, but www.bulltear.com might sell something that would work. they do a lot of custom built and machined stuff and they have a great forum too.
Tried bulltear, they make alot of stuff, but nothing for rear main. Guess i am stuck with a 2 piece.:mad:
I looked and I haven't even found someone who has machined a block and cap to do it. There is no way your going to do this without tearing the engine apart and taking the block and the rear main cap to a machine shop. It's just not possible without some milling work.
