Misc. One piece upgrade
Scout1067
Old Time Jeeper
Germany
1981 CJ7, 258, T176, D300, D30 front diff, AMC 20 rear diff, Weber Carburetor, BDS 2.5" lift
If have done this and is exactly what you need to do. An axle on the Dana 20 means you drive to work with front hubs locked... (been there)
Keep the updates! :chug:
Passenger side also came right apart. A friend had a press and got the bearings pressed onto the new axles. Now just waiting for my my new brake lines to get here and I will be rolling again.
Sent from my SM-A405FN using Tapatalk
We fully understand
I hear ya...Did my swap a while back and I don't regret a thing. Front brakes came from Horsepower LLC, and rear brakes came from TSM Manufacturing, but that was for a Dana 44 .
Good job, looks much better. Once I got the all the right parts in and adjusted correctly my rear drum brakes work pretty well for non power assist. I even got the parking brake to work well and will even hold on a down hill.
I will wait for the life of these before doing the conversion but research and acquiring parts will probably start soon
Scout, may I ask how or why the bearings got ruined?
Because I was tightening the axle down without removing the thrust block first. This caused the outside end of the bearing to bind against the brake backing plate and provide uneven torque ruining the bearing. It took some serious head scratching, googling, and a call to the Moser tech line to figure out what was going on.
This is my understanding of the theory. Apparently on only some versions of the AMC20 the 2-piece axles have a funky taper and some play in the layeral travel of the axke shaft during operation thus the thrust block in the diff to maintain axle separation during operation. There is no play in one piece axles and the thrust block needs to come out. At least that is how I understood it from the tech.
That's interesting, my 20 had the block, it was a stock open 3.54:1. When I put the G2 axles in the instructions had a warning about the block. Is yours a wide track?
Ok, I can see why the thrust block needs to get deleted. Carefully grinding down and shortening the new axle shaft on the splined end would have saved the labor of popping open the pumkin to remove the thrust block, without any adverse effects. Thrust on the new shafts, however, still needs to get adjusted and minimized by shimming the bearing against the backing plate. Hopefully the new shaft tolerances negate any thrust adjustment.
I did this upgrade on my AMC20 more than 10 years ago, but I don’t remember having a thrust block, or removing one. It was a narrow track with 3.54 gears.
I have the stock ratios as well. The instruction sheet from Moser said zip about potential thrust block issues. Luckily after ruining the first bearing I did a bunch of research and ran across some references to a thrust block on another Jeep forum. The Moser tech acknowledged that their instruction sheet that comes with the new axle kit could be improved and they actually cut me a deal on replacement press rings (they sent me two for the price of one).
What irritated me the most is it cost me 3 1/2 weeks of the CJ up on jack stands waiting for parts to get to me in the mail. Sometimes it seriously blows being stationed overseas.
Moser is in part at fault for this mishap. This is a kit, not a “custom order” set of shafts. Therefore, full instructions should be included. I have bought custom made shafts from Moser in the past, and of course, I did not expect included instructions. Glad this is all over with no catastrophies and a win-win end result.
Luckily it's done now. Absent something breaking the next major project on the Jeep will be body work and a new paint job in the spring. I will be pulling the tub for that.
I think I have all the major mechanical problems and PO goofs fixed at this point. Now it's just playing and going for the mods I want.
Thanks Scout1067 for sharing this, and for making me realize I should never attempt to do a single axle conversion on my AMC20 . 😁 My amateur skills will lead me down a rabbit hole of pain and suffering. I'll leave it to the experts.
Thanks Scout1067 for sharing this, and for making me realize I should never attempt to do a single axle conversion on my AMC20. 😁 My amateur skills will lead me down a rabbit hole of pain and suffering. I'll leave it to the experts.
It's not that bad of a job. The job itself is actually pretty straightforward and if everything goes the way it should, can be done in an afternoon. What took so long for me was the lack of any mention of possibly having to remove the thrust block from the diff in the sheet from Moser and that the old brake lines fell apart during disassembly. So I had to order three things I had not initially identified, 1. a new bearing, 2. new press rings for the one-piece, and 3. new brake lines.
If that had been in there I would not have ruined the first bearing. It was waiting for the new bearing and press rings that took forever. Once I got the second bearing installed on the one-piece driveshaft I had it put back together in about 2 hours.
1/2 of the fun of having a CJ is working on it. I say that with mine being my daily driver.
