TCase Orangey Transfer Case E-Brake?
Transfer case
jeff_b
Missouri
70 CJ5 350/350
Pre-1972 CJs had the driveline parking brake setup. I believe the 1970 should have that using the Dana 18 Transfer Case that has the parking brake feature. Not all T-18 's had that however. It doesn't look like yours does.
Pre-1972 CJs had the driveline parking brake setup. I believe the 1970 should have that using the Dana 18 t-case that has the parking brake feature. Not all T-18's had that however. It doesn't look like yours does.
I looked at the rear drums, no provision for parking brake cables......dang, did the factory sell these farm implements (lol) without parking brakes?
It's possible someone took the Transfer Case mounted brake off since there is evidence....The small stud hanging down is where the lever would have been mounted. They often get covered in oil and don't work or the stud has broken off, as is the case in two of mine. I'm planning to fix mine when I rebuild my TC this winter.
$20.00
  10.0%
