hi might be a dum question but is the add on Overdrive used or good for on a jeep been checking the internet not much found or to technical for my old brain thanks
former owner made lots of changes haven,t checked every thing out yet
looks like stock tires but he put in a 3 speed don,t know which one and haven,t
looked to see what Transfer Case i have. this little CJ5 will be mostly or around town but will also see hunting use.so there will be a lot of highway and interstate use every place i go is between 200 and 700 miles from casper thanks
What engine do you have in this CJ?
OD-Saves wear and tear on the engine by reducing RPM at freeway speeds.
Do you have a tachometer now? If you do, what rpm do you see at 65mph?
AMC 258 i6 / 4.2l is red lined at 4500rpm.
Is your CJ a 5 or a 7?
Please fill out your vehicle profile.
We need to know your R&P ratio, and tire diameter.
There would have been no 'add on' Overdrive for a later model CJ. As posted, there was a Saturn/Warn OD that could be added to the Model 18 Transfer Case . Your 81 CJ5 would have had the Dana 300Transfer Case .
Being your's is an 81, it may have the T-5Transmission , which is a 5 speed manual with 5th gear Overdrive .
AMC put the T-5 's in trying to get the CAFE up on a brick moving through the air.
Generally, an Overdrive is good if you want to run lower axle gearing (high numeric: 4.11, 4.56, 4.88, etc.) but don't want the engine screaming while going down the Interstate at 70 mph.
