over drive
over drive
gindy
casper wyoming
1981 cj5
hi might be a dum question but is the add on Overdrive used or good for on a jeep been checking the internet not much found or to technical for my old brain thanks
All depends on your R&P ratio and tire size, along with what speed you want to run.
former owner made lots of changes haven,t checked every thing out yet
looks like stock tires but he put in a 3 speed don,t know which one and haven,t
looked to see what Transfer Case i have. this little CJ5 will be mostly or around town but will also see hunting use.so there will be a lot of highway and interstate use every place i go is between 200 and 700 miles from casper thanks
Sounds like you have a Transmission from 72-79 could be a T-15 or T-150 with a Dana 20 Transfer Case
Add-on Overdrive , the warn OD mates to the rear of a D18 which I'm guessing you don't have. Least expensive way to add an overdrive would be to swap in a trans that has one.
What engine do you have in this CJ?
OD-Saves wear and tear on the engine by reducing RPM at freeway speeds.
Do you have a tachometer now? If you do, what rpm do you see at 65mph?
AMC 258 i6 / 4.2l is red lined at 4500rpm.
Is your CJ a 5 or a 7?
Please fill out your vehicle profile.
We need to know your R&P ratio, and tire diameter.
TNX-See that now.:o
I asked, because his profile info is a bit confusing as to model. :D
There would have been no 'add on' Overdrive for a later model CJ. As posted, there was a Saturn/Warn OD that could be added to the Model 18 Transfer Case . Your 81 CJ5 would have had the Dana 300 transfer case.
Being your's is an 81, it may have the T-5 Transmission , which is a 5 speed manual with 5th gear overdrive.
AMC put the T5's in trying to get the CAFE up on a brick moving through the air.
Generally, an overdrive is good if you want to run lower axle gearing (high numeric: 4.11, 4.56, 4.88, etc.) but don't want the engine screaming while going down the Interstate at 70 mph.
3 speed, this is why I suggested it was a T-15 or T-150 as the 3 speed never came in the newer 80s model. If it is they are mated to a Dana 20 .
Knowing your R&P ratio and tire dia would be a BIG help.
