Plumbing
Plumbing
Germy
Full Time Jeeper
Cincinnati, Ohio
1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
See my responses in blue.
What is the big threaded hole
That's just a vacuum port. You can hook your brake booster up there.
Pcv valve, does brake booster or carb go there?
Run a hose from your PCV to the 3/8" port on the back (or front, if you have an edelbrock) of your carb.
Fuel?
Yep.
Fuel goes in pump, then out the threaded fitting into thre filter to the carb and from the second port of filter goes to return
You got it.
Is this just a vent, it runs alongside return on frame rail
That may have been a tank vent line to your charcoal cannsiter...follow it back the frame and see where it goes.
Sent from my iPad using Tapatalk HD
