Possible transmission crack
ttbiker
Springville, UT
'76 CJ7
So, I'm was finally making progress in getting my GM drivetrain all put in my CJ7 . I just tore down the TH350 Transmission for rebuilding. While cleaning up the case i noticed what looks like cracks. Its possible that they may just be casting marks, but I'm not sure. Does anyone know if these are cracks or casting marks?
I cant seem to get pictures to post, so here is a link to the images on onedrive: https://1drv.ms/u/s!Ag6bmpfm1KWxgeJksD8YtQ4wPu87iQ?e=dc7IPB
So, I'm was finally making progress in getting my GM drivetrain all put in my CJ7. I just tore down the TH350 transmission for rebuilding. While cleaning up the case i noticed what looks like cracks. Its possible that they may just be casting marks, but I'm not sure. Does anyone know if these are cracks or casting marks?
When I read your post, I thought for sure they would be casting marks.... I've seen em that look sorta like a crack but are actually raised just a bit - but I gotta say those do look like cracks. If they are, you should be able to tap the housing in the area of the cracks with a screwdriver shaft and hear a difference in sound than in an area with no cracks. If they are cracks it should be more of a dull thud than a metallic ring.
It looks like a crack to me.......
Yah im thinking about getting it checked out at a machine shop. I can definitely say that there are no Crack marks on the inside of the case. I spent over an hour looking inside and found nothing bad in there.
Thanks for all you opinions about it!
