Build Thread Project " Un " Limited
Get to work slacker!
Here ya go Pete. This should keep you occupied for a few hours.
Autotransmissions - YouTube
I've got a TF999 in the shop (two actually) that need a rebuild, and I can't find anyone around here to bench build them, so think I might attempt it myself. Anyhow, replacing that seal should be in there somewhere.... This is for a 727, but almost the same thing as the 999 (think a lot of the rebuild kits cover both trannys)
:notworthy: It must be nice to be able to have the choice of what CJ to put in the garage. :drool::drool::drool:
Its nice if its not a necessity. Having two Cjs battle for the same garage can turn into two half done projects and no money for either pretty quick. Been there done that. :( The Limited will get some work done little by little till my next free weekend Sept 14th. Then the Laredo reclaims the garage for the seal change.
Thanks for that. Im going to convert the SM465 I have in the garage to accept the Dana 300 first. After that I'll maybe I'll attempt some more in depth auto Transmission stuff.
In fact its time to get away from the computer awhile and start cutting away sheetmetal. ;) Right after I pick up the Laredo . Shop just called.
it's bright. what shade is it?
I'll have to check when I get home. It was a little brighter than I was looking for but I think it'll grow on me
Johnny the color was called "Brilliant Blue".
Worked some more but dont have time to upload pics. Lets just say carpet in a Cj was the stupidest option ever. :rolleyes:
You can get a nice pint job AND the color of your choice by using a Preval sprayer. They come with an aerosol sprayer with a small bottle on the bottom. I've done many small jobs using these sprayers. The glory of it is you can go to your paint store and get any paint you want, any color you want. Just mix and spray. I think the spray quality is far better than a rattle can at a similar price.
Thanks , I will have to keep this in mind cause the plans for the Cj have just taken a big turn. My brother Mark was over tonite and we spent some time looking over everything I have while the welding man was here. It looks like the "steps method" I talked about earlier is going to change.
The Yj tub I was trying to give away will actually be used for this project. Mark is picking up the tub , boatsides , floorpans and some additional sheetmetal on Friday. The Cj tub has some patches already under the roll bar , in the floors and wheelwells and needs more. The Yj tub is in better shape and will be his project now. I am extremely greatful for this one. Not having to worry about the welding changes everything.
That doesnt mean things got easier for me. I'll be balls deep into the frame off now. Its gonna be total tear down time. Everything will be cleaned , primed and painted. Guess I'll be starting after the Holiday weekend. Here goes Something...:chug:
I can't believe they put those %^&* Torx headed bolts back in there! I only kept one for reference on size, the others met their maker across the fence...:D
Just keep taking it apart Pete, you will have it scattered out like feeding chickens in no time.:chug:
$100.00
  50.0%
