Build Thread Project " Un " Limited
Thanks for the info. My last two Cjs had the T-176 as well. Its a good Transmission and Ive had alot of sucsess with them before. For the type of wheeling I have planned for this Jeep the SM465s 1st is going to be perfect. I'll go down to the garage sometime today and see if I can decipher the codes you gave me.
Congrats on the Limited. The underhood insulation IS original, and the underhood light takes an 1156 bulb (1157 is double filament for tail lights, 1156 is single filament for reverse lights, underhood light, and also is a brighter option for interior floor lights, although you have to ditch the bulb covers)
What exactly is wrong with the T176? The SM465 is a good tranny, but the unsyncrod first gear isn't fun to drive around town. I have one in my old GMC pickup though and I just start in 2nd. T176 should be a pretty easy rebuild, and if you check the tag, you MIGHT already have a T177.
T-177 (3.82 first gear) will have the number 5359389
T-176 (3.52 first gear) will have the number 5359390
I'm guessing you'll have 2.73's since that's normally what came with the T176, BUT, if you look to the right of the pumpkin, there will be a letter (or letters) stamped there.
D is 2.73 open
DD is 2.73 tracloc
B is 3.31 open
BB is 3.31 tracloc
I've got a Dana 30 with 3.31's in my shop, and have been looking for an AMC30 with 3.31s to swap in. Guessing shipping would be a killer since I'm down South, but if you end up swapping out for an 8.8 rear and yours is 3.31 holler before you sell it.
:shooter::barf:
Like I said I want to keep the Limited theme it came with from the factory , but it will end up a heavy resto-mod. Thats the first stage I hope to have done before the snow really starts to fly. This will be the winter Jeep cause I dont want to "salt" Vickis
