quadratrac
quadratrac
cj7mudder24
Lowell, IN
78 cj7 quadratrac straight6
im looking to get rid of the QuadraTrac t case, what tcase should i go with along with what axles should i go with? Help is greatly appreciated thanks:)
We would need to know what your plans are for how you will be using your CJ before we can begin to recommend something like that.
Why do you want to ditch the QT? Are you planning to keep the Transmission in it already?
reason im geting rid of the QuadraTrac is it dont have a low range the one i have dont have the box for it. Also i wanna be able to put it into 2 wheal drive. The jeep is more of a silver lake/street/ carshow toy
You have 2 options I would recommend:
1. I already mentioned that you can get a Dana 300 , A $500 adapter, and replace the rear axle.
OR
2. Get a QuadraTrac with the low gearbox. (this gearbox can also be bolted to your TCase). Rebuild the QuadraTrac with a Milemarker part time kit for $400. You can then add locking hubs. This option will cost less because you won't have to replace the rear axle and the drive shafts won't have to be modified.
http://www.amazon.com/Milemarker-95-91203-Conversion-Overdrive-Quadra-Trac/dp/B000FQ97AS
See also: http://www.jeep-cj.com/forums/f105/transfer-cases-12108/#post97071
do you know where i can get a low range gear box?
I think you might have to get the whole TCase used, maybe at a salvage yard or eBay. My thoughts are that you could either rebuild the TCase or just use the low range gearbox on your TCase.
I have one on the rack, but I am not equipped to ship anything of that size. You feel like a 13 hour drive? lol
