Reverse light switch and general tranny questions.
nctom
Asheville
77 CJ 7, 258 i6, 3 speed
Looks like a Tremec T AMC 150
A- is just a vent with cover and should feel loose
B- is Speedometer connection
C- is backup light switch
Fantastic, thanks! I am going to clean it up before I dig into the backup light problem.
let's try again
assuming it's a T-150 under all that grime:
A = vent
B = Transmission controlled spark switch (emissions, high gear only)
C = Back-up light switch
Speedo cable connects at the Transfer Case , not the transmission.
Thanks, I found a TSM online - it confirms that this thing shipped with a T-150 . I appreciate your help.
tm
let's try again
A = vent
B = transmission controlled spark switch (emissions, high gear only)
Speedo cable connects at the transfer case, not the transmission.
That transmision is identical to the T-150 I just rebuilt for my '77 CJ5
B is the speedo connection and
C is the back up light switch
The Transfer Case has no provisions for any connections of any kind.
I agree whole heartedly!!
you need some de-greaser!:D
I de-greased the top of the Transmission so I could work on the switch. After a good cleaning, it tested fine. Thanks for your help!
    Best for votes
    on specific items
