serpentine upgrade??
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
OK so the big problem is I am getting tired of the V belt squealing on the 140 amp alternator but with power steering on the horizon as well I think a serpentine belt set up is a good idea. The only question I think I have is how hard it is going to be to put the serpentine pulley on the crank. this will be, I am guessing , an 80 something pulley/balancer on a 77 crank.
any thoughts??:cool:
found something interesting tonight. Summit lists and stocks serpentine belts by number of ribs and actual length. In 1/2 inch increments. How cool is that!:cool:
Try getting that information from the local parts house!! Back in the day, they used to actually know what the code on the belts meant. Now they dont have a clue.
If you go to a local parts place they usually have the belts about every 1/2" or so. I've had to run back and forth increasing/decreasing a half inch at a time until I get it right. I do prefer Summit to Autozone; but they have worked for me on the belt issue. Last three digits is the length.
$45.00
  22.5%
