Build Thread Starting from the frame 1977 CJ5
There is that cool Summit box again.Ok the driver side hub turns but it is not free. Have to use a wrench to turn it. I’ve cleaned it de greased it as best I can. Any recommendations on how to free it up?
CJ I ordered a body bushing kit with the body from Willy's Overland. Jay told me the holes on the mounts may be a little small but just bore them out the 1/16th and all should fit great.
The gear inside when I install it with it turned to 4x4. So it’s extended the gear will not line up or slip over the axle splines. I’ve tried rotating it and it doesn’t slip on. Just compresses those springs.
