T150 Stuck Cluster Gear shaft end plug
mechjono
kaplan louisiana
1978, cj5, 304 V8, T-150 transmission, Dana 20 T case , all driveline stock, currently a project that is not running.
Sorry I haven't posted in a while, havent worked on my jeep in a while.
I am back at it. Trying to rebuild my T-150 Transmission and would like to get the end plug out of the housing to make it easier to reinstall the cluster gear shaft and gear bearings. Can't seem to get it out, tried some heat but it did not move. Was scared to break something so I went another route to remove the shaft.
Does the plug push in towards inside of the case or does it have to be pushed outwards. Any info would be appreciated.:confused:
What a dummy.:eek: I figured it out. Just push the shaft in and it pushes the plug out. Thanks for the forum anyway, lots of good info here.
