TeamRush Ignition Upgrade
alpha6
Old Time Jeeper
That's what would happen if you always have 12 volts on the red wire that goes to the old coil connector.
the red wire in the top of this drawing should have 12 volts ONLY when the key is turned on.
I would hook up the ground and everything else. check the red wire that goes from the old coil connector into the MSD module. There should not be 12 volts there until you turn on the key. If there is 12 volts that's your problem. Dont start your engine or it will stay running again.
If there is 12 volts there don't leave it like that overnight. It will drain your battery. Disconnect the battery or the ground MSD wire.
EDIT: It's good that you didn't make a permanent connection where the old coil connection goes into the MSD harness. Disconnect the coil connector and check for voltage on the red wire in the CJ harness (not the MSD harness). That red wire should not have 12 volts on it until the key is turned to the ON position.
Ok, just tested it and there is no power to the old positive coil red wire when key is off. When key is on it does have power. Turn key off and no power to it...so what now...
