Electrical Temp sensor wire location in engine bay
Caddo Mills
1991 YJ, 4.0, AX15, 1976 CJ7, restomod, quadratrac
Does anyone have or can someone take a picture of the wire going to their temp sensor on the firewall, inner fender, etc. The 1982 CJ8 I'm working on did not have the dash temp sensor connected and there are no "spare" wires on the harness. Thanks in advance.
Should be purple or violet with white trace coming from fuse block going to sender. Same from fuse block in the cab to the temp gauge.
Thankyou, I had found that online and located it easily on the guage but having trouble under the hood due to a past "overheated" event where the wires come through the firewall, Lol. I was hoping someone could snap a picture showing where it enters the harness from the sensor going back.
