Build Thread The '80 FrankenJeep frame off reassembly
No I have the same little cover on mine, the factory dropped the ball bearings in thru those holes
THANKS - My first thought was “Oh :dung:, I’ve lost something”. Rather, something else..... LOL
Sent from my gas grille using Tapatalk
Lol I looked at it and said what kinda cheap sh$t is that
T177. Supposed to be a T-176 but the tag says otherwise..... I can only imagine where it came from.....
I thought that’s pretty neat
Oh, man - that makes me hurt just lookin at it.....
I wasn’t wearing the glasses cause I had the wheel running slow - but always wear glasses otherwise. After this I’m buying a shield. I do make a point of keeping the “ rotational disc of egress” well away from me, but that may not be sufficient.
And I see I’m not the only one who documents injuries for future reference.
Wow you were really lucky in a way there. I don't think at the time you probably didn't feel that way. I worked with an engineer several years back who had been working at a machine shop many years before that and someone had been grinding on something and the wheel came apart and flew a couple hundred feet in the air and put his eye out. Glad you are ok now. I remember seeing that picture a while back Just remember scars give you character. I've got a few also. Proof we lived and learned something and help others along the road of life with knowledge!
It felt like I got punched in the nose. My eye wear got a gouge in the edge of the lens so it would have been worse. But anytime I use the grinder or cutting wheel, i put on the face shield now.
We have 2 pairs of safety eyewear that have been saved at work because they worked. 1 has hot tar that was slashed on it. The other has a small hunch of metal stuck into it. That stuff works
Yes it does - I’ve had a couple pairs of glasses do their jobs, but the aftermath wasn’t worth saving....
Ouch my face is hurting now
Wish I knew why I keep getting double posts......
Happens when the system is slow and you think it did not post and then you hit the Post Quick Reply button again ? Happened to me a couple times.
