Build Thread The '80 FrankenJeep frame off reassembly
When I was at napa a couple of weeks ago the largest I could get they said was 85 amp. So I went with that for a 85 CJ
Yeah, I could just not put em up - I rarely use em...... but it looks unfinished without em. And yes, I seem to complicate everything I do. The visors never crossed my mind when I built the box....... Then again, it’s as narrow as it could be so the visors would have lost anyways......
Not to mention the fact that if I’d just left everything stock I would have these challenges
Sent from day 3 of sunshine.... WHAT THE HECK??
I’m also a big fan of the rare earth magnets - but they’d never crossed my mind for this till I saw em at the hardware store....... I figure it’s worth 5 bucks to see if they’ll do the job [emoji106]
Sent from the rainy, East coast version of Seattle.......
That little gizmo looks like it might work better than OEM prop rod holder.
You weren't kidding when you say you like to it the hard way. I figured some flat stock and a hole in it and bolt it in, similar to stock. Not you, no one else will have that!
You are correct - an OEM similar piece would have been easy enough - but this took less than an hour to rig up. Besides, the square tubing was handy and I don’t have any flat at the moment....
Sent from the couch using Tapatalk
Good on you shum8
dang thats a beefy bracket way better than factory
Ya, just because I had 2” tube scrap handy. And this project was a bust - the pistons are too strong. I think I’ll go back to the original springs - just need to work out how to attach - OEM hardware and sleeves are in the wind
what about new hydraulic ones from parts store arent they relatively cheap?
If I can find em weak enough - the two I used would worn on an Abrams tank.....
$150.00
  75.0%
