Build Thread The '80 FrankenJeep frame off reassembly
Once again, awesome work... I can't believe it's so clean. However, you'd better knock on wood about the no stuck/broken bolts yet! Apparently, I've got the same leaky can of anti-seize... I touch the can with gloves on, it's immediately all over my hands despite the gloves and I'm wearing it, too. :rolleyes:
And I've gotta ask, since I'm on the market for one... How much for your old tank? Any idea of price on the ride via the brown Santa?
Alrighty, then - worked on my exhaust the last couple days...... The sections of exhaust were all clamped together, so I removed all the clamps, removed the last section that dumped out the rear inside the frame rails, and bolted it back up to the headers. Once firmly bolted to the header flange, I used a pipe wrench to rotate some of the sections to tweak the route to suit me. Got em where I wanted em, then tacked em in place with the welder. After work today, finished welding all connection up. Once back on the road, I'll run it by a muffler shop and have em run turnouts so it dumps out the side behind the rear tire. The way is was run before, driving without the top sucked tons of exhaust into the cab.....
I didn't take any pics - this wasn't very exciting nor interesting. Now to get off my butt and order body mounts and start emptying the tub so I can get the last little bit of bodywork done
Looking good :popcorn:
im so jealous :chug: I absolutely love that AMC blue engine, I cant wait to have mine finished and looking that good. Good work
Thanks for the kind words - when you get around to buying the paint, don't listen to those who say it doesn't cover well...... I intended to buy 3 cans to make sure I had plenty, and the pricing was such that 6 cans only cost a bit more. Well, I now have enough AMC blue that I could probably paint the entire Jeep with it LOL. It goes farther than some say......
If you want to sell your left over paint let me know
IM inbound...
I have not received a message yet did you send a pm?
Try that - hopefully that one went.....
Yeah, that fuel return line is kinda hangin free, but that pic was taken before I got it clipped up. Since I was referring to the exhaust in this pic, just don't look at the fuel line. Stop it. Quit lookin at it......
:laugh: looking good :popcorn:
:chug: you can barely tell that you drank before you butchered your crossmember :laugh::laugh: looks really good actually. I like how you thought it thru and made one cut I will have to remember that for when I put my YJ tub on my new crossmember
Was only one..... Took the dogs out in the yard and enjoyed some shade with em.... Then the disassembly started - that barley pop was long gone by the time I grabbed the grinder.....;) Thanks - if you get the light just right it looks good - almost can't see the pits :D
That's just a result of being lazy..... And I think I still have another set of mount supports to deal with. May be some more cutting and welding going on.......:rolleyes:
Looks really good. I like your home made crimpng tool. I usually just use a hammer. :p
Wow haven't heard of shortening the body mount sleeves but it would be the bottom pic that you would want to trim, have you checked the bushings on the frame yet just to see if they do need to be trimmed?
$150.00
  75.0%
