Build Thread The '80 FrankenJeep frame off reassembly
I'm thinking he's out wheeling it and didn't even let us know
You done anything on your Jeep lately?
Uh, no and no..... Even tho I don't get summers off anymore, I somehow haven't been able to shake the summer jobs..... only thing I've done to the CJ lately is install a new soft top. Which reminds me - I need to list the old one and see if I can sell it.....
It's like coming home again!!! Via Tapatalk
The hinges on mine are steel...so you could weld up the open slot and re drill as a fixed point...and..if you can push out the top deformation...I would cover one side holes and inject resin into the void..should be able to create a solid core at the hinge point..jmho..happily ..mine was still good...
That’s the plan for the hinges- but as for the deformation - it must be hollow at the spot? I thought about reinforcing the interior area, but wasn’t sure if it was just dead air........ hard to get a structurally sound filler in there with nothing to make it stay. And I didn’t want to cut into it if I could help it.
Wonder what’s inside there??? Did they all have they bolts there or was there a blind nut setup inside that’s broken loose...
Sent from right here.......
Pretty sure the captive nuts were imbedded..or possibly threaded fibreglass ...less likely..
could always use hi density expanding foam..that may well get you enough support
for through bolts
Unless there is scenery to see, usually the easy road is best. :punk:
Interesting. I need to do the same thing for my seats.
Super job ! Is that the frame from a YJ or CJ ? Looks slightly different.
Man, I’ve been pondering this for a year, was either lose some weight or modify this seat bracket but still try to maintain the fold forward... a year later, still pondering how to cut the brackets [emoji23]
That is a YJ bracket - It what was in there with the YJ seats, and I didn’t have the heart to cut up my CJ bracket.
I hear ya - that’s why it’s taken me so long to swap it........ Wasn’t looking forward to this, but finally got tired of stepping around the seat in the basement. As for the cutting - a couple cardboard mock ups says it’ll work. With the geometry involved, reducing the height by 2” only required removing a little over an inch of material...... The front riser pieces and cross braces are a piece of cake - but the rear risers need the latch pins to be relocated. They will be situated after everything else is welded up. Drill a mounting hole and weld both sides.....Stay tuned.....
Over on the CJ8 forum there is a great write up with diagram and pictures and measurements on cutting and welding the brackets.
Well, let’s see if I can sneak back in here and toss an update on here…. Been an interesting, frustrating, and joyous few months. I’ll get the ball rolling, then add more later. Early November, clutch started slipping, so I ordered a new clutch setup from Rock Auto, and took everything to a buddies wood stove heated garage and swapped it out. Fast forward to early Feb…… Drove out to the DMV to renew my drivers license, was almost home, and when I pulled away from a red light, it sounded like the pressure plate was scraping the inside of the bellhousing. Not possible, I know - but that’s what it sounded like. Dropped everything aft of the engine, found a rotten throw out bearing, so I thought “ this won’t be too bad. Since that was my first purchase from Rock Auto, I blamed the clutch set. Picked up a new one from Napa, grabbed the throw out bearing to see if that was the source of the noise. Nope. Still scraping and knocking around. So I dropped everything aft of the engine, again, and replaced the rest of the clutch set. Put everything back together and fired it up. Noise was a little different, but still there. Dropped everything aft of the engine, again, and decided to start it with nothing but a bare flywheel, then add one piece at a time till I found the culprit. Cranked it up, and viola - a bad rod knock…… And there was my first WTF moment.
Ok - time to crash. I’ll add more tomorrow …. With pics 👍
Had to add this - Wanted to give everyone time to come up with ways to tell me I’m stupid…… It’s coming - I can smell it LOL
Not us . What a dragggg.
$150.00
  75.0%
