Turn key solenoid clicks....
stivel74cj5
I have a a 74 CJ5 with a AMC 258 i6 / 4.2l which i believe has been swapped with a 75 258. Ive replaced the battery, starter, starter solenoid, and ignition coil. I am still only getting a single click from under the hood. Ive bypassed the solenoid using jumper cables and the starter spun (i had taken the starter off the jeep) the ignition switch is new from previous owner. the wiring harness is gone and replaced by a rats nest by the PO and no ignition module but 2 small fuze boxes. one has a constant from battery and one is on only during the 'run' mode. i have cleaned the connections and grounds, and replaced wires running from battery -to- solenoid -to- starter. and battery-to- ground (engine block). I am at a complete loss
please help
) I borrowed a volt meter and it read that current was getting through properly. thanks tho. H4zY
