want to upgrade to hyd clutch
I have a 85 cj-7 with a 360. I wanted to install a hyd clutch. Has anyone ever done this before. If so who or where is the best place to get parts?
I've wondered about this one too. Will a YJ slave cylinder bolt to the bell housing for a factory T-18? What about the pedal linkage?
You dont want a YJ internal slave. That idea ranks right up there with the D35 C-clip axle.
You can source all the parts you need from Napa (slave, master, and lines)...except for the pedal assembly. That, Im pretty sure would be best found in some classified section, Ebay, Craigslist. Try to find a stock assembly....Anybody aftermarket that is making them will want a fortune for them
Edit: Your bell housing will have the mounting ears (2 holes, maybe 2½-3 inches apart) Get a measurement between those holes...If I remember correctly, there are a few slave cylinders out there that have different measurements between mounting bosses.
I was asking about a YJ external slave if it would fit, so I would know what to ask for from the parts store. I would never install a used master or slave, but I might be inclined to pull some from something at pick-n-pull or off of craigslist to use as cores and for linkage and whatever wouldn't be available from the parts store if the price was right.
So a YJ pedal assembly should work with a lot of different masters?
What about linkage?
It would probably be best if I pull everything from another vehicle so I can know what all parts I need, and then swap the old master and slave for new ones at the store.
I wasn't aware that they ever put a hydraulic clutch in any CJ?I would source CJ parts from the parts store. YJ clutch parts come as a unit (meaning the slave comes with the line) and they are expensive. The CJ parts will be individual (slave, lines, master...) Plus there is a better probability of matching a CJ slave to a T18 bell housing. I really dont know if a YJ pedal assembly will work with a CJ master cyl. There could be a 'throw variance' between the pedal and the piston for the master cyl.
Honestly, I would just look at CJ clutch components and a CJ pedal for ease of installment.
There really is no "linkage", the pedal attaches directly to the plunger of the master cylinder through the firewall. Again, compatability is suspect![]()
Are you sure the clutch pedal for a standard clutch is different than one that connects to the rod from the master cylinder?
My 85 CJ-7 had a hydraulic clutch from the factory in it. I kept the hydraulic when converting to the V8 engine. The master cylinder is the same and the slave with line parts were different. They came separate and I had to modify the slave slightly to clear the oil filter by grinding just a slight bit off the gusset cast into the slave. I think Omix-Ada and Rugged Ridge are the company names the parts were sold under. They are available from Quadratec, 4WD hardware or probably even Collins Bros. would carry the parts. It wasn't that expensive and here is a writeup on how to convert a CJ-5/7/8 clutch pedal to use the hydraulic master cylinder : Hydraulic Clutch . It's really easy to do the conversion without special clutch pedal arms etc. I would add the special nylon bearing sleeve over the pivot stud though that was used by Jeep and not shown in this picture of parts. You can order one for a 1990 5 speed XJ Cherokee and it works perfectly as a substitute. It will keep the clutch pivot bolt from wearing out by virtue of metal-to-metal contact with the clutch rod eyelet of the master cylinder. RangerRick
Another quick note,
If you have headers or the exhaust runs closer than 2 inches from the slave cylinder, make sure you install some kind of heat shield like is shown in the writeup or the seals in your slave will prematurely fail due to the excessive heat. Now another hint is to use two pieces of all-thread and a union with two nuts for the link rod at the slave cylinder. Fit the nylon tip onto it at the clutch fork and use a grinder to slightly round the end that fits into the slave cylinder's piston cup. If there isn't enough travel to completely disengage the clutch when stepping on the pedal, you can adjust the all-thread a small bit and lock down with the jam nuts for your disengagement "fine-tuning". Make sure there is a good sized helper spring installed to keep that throwout bearing completely away from the clutch diaphragm fingers and seated against the nylon tip of your slave cylinder link rod. Once you go to hydraulic clutch linkage, you'll wonder why it took so long to do this upgrade!
RangerRick
Another quick note,
RangerRick
I would love to convert mine but not sure what I need and how to do it. I have 77 CJ7 with a 304 and T4 tranny I think. Too bad there isn't a kit and detailed instructions for those of us that don't do alot of mods....![]()
