Water Pump and Thermostat
phinleft
- Baton Rouge, LA
- 78 CJ7, Amc 304 V8 - AMC 20, DANA 30, Quadratra Trac TH400, 35" Mickey Thompsons MTZPainted LSU Yellow/Gold. Modified with 4bl Edelbrock Carb.
The water pump on the CJ has started leaking and draining the cooling system. I am going to replace it in a week or two, but wanted to get everyones oppinion. When I replace it, should I replace the thermostat at the same time. If so what temp thermostat is suggested for a 76 CJ5 ? Anything else I should consider replacing while it is apart?
