Changed a bad front axle u-joint that I found while giving the jeep a going over after being parked all winter in preparation for spring.
Chased down a couple "here today gone tomorrow" electrical issues. At least it appears that they are finally gone. Time will tell.
When something is broken it can be fixed, when something doesn't work quite right or all the time, it becomes a real PITA.:D
I'm tellin' yeah that is the absolute truth. The problem would be there one minute gone the next. After a month or so it became obvious that part of the problem was in the plug from the turn signal switch. As it turns out most all the tail light wiring goes through that plug. When I lost the left rear lights a squeeze of the plug would restore the lights. I finally got the darned thing apart, cleaned all the terminals, found one that wasn't seated quite right and one that the wire attachment point was questionable. When you find something wrong and fix it, it's a good day. There were also problems with the back of the fuse box. Lots of metal grinding dust in there, didn't know there WAS a gap behind the fuse box. Cleaned and replaced all the terminals back there too. Lights and such are MUCH brighter now. From now on when welding and grindin ing the tub I'll make sure to hit that space with air.
Tested out the Lokka locking differential I installed over the weekend on some snow covered side roads. Very pleased. The boys wanted the doors off for the ride and found out that 25 degrees F is a lot colder at 40 mph.
Yup, you'll like the aussie locker.
I see your questing the rear axle gearing in your sig, the "X" is a 3.07 open diff.
I drove 29 miles round trip, when the temperature was 27 degrees F. for a $23.20 Pennsylvania state inspection.
I now have now fresh sticker on my windshield.
I could have driven all day.
This thing is SO much warmer than a motorcycle.
Im so glad I don't have to get mine inspected any more. 35 years or older are exempt in North Carolina.
Sent from my Milestone X2 using Tapatalk 2
Thanks for reminding me I need to update that! I counted the teeth while I was in the rear diff and verified the 3.07.
Packed hub bearings with grease, anticipating putting them in tomorrow or the day after.
Looking good Hedge. I like the way you've down sized that CJ5 . Most people look to lift their Jeep including myself , but you have a winner in the "Witch". Now you have me hungry for rabbit as well. ;)
Thanks - One odd thing for these days. As you can see in the bottom picture there were absolutely NO ATV tracks on this road/trail. Granted this was a road with long seriously steep climbs with the necessary down hill grades as well, but when has that ever stopped an ATV. An all around good day to be in Arizona and a Jeeper.
Thanks for the kind words. The 76-85 never came with SS trim rings. The next best thing would be to purchase a loaded 72-75 grill. The center mount on the 72-75 is slightingly different and may need a bit of tweaking to fit properly.
Side note: There is no aftermarket support for the SS rings, buying used is the only way to get them, unless you already own a set. There is aftermarket support for the lamp and lens.
Amazon.com: Crown Automotive J0989852 Front Parking Lamp: Automotive
A few months ago I found that my rear axles were bent. Rob at Willys Works had a used set that were straight so I bought them. The axles came with the old hardware installed with good tight bearings, but no races. I was in a hurry to see the old girl on the road so I used my old races fully knowing that it was a temporary thing so I could get the Jeep on the road. So, yesterday I pulled the axles. When I put the axles in the bearings were tight and new looking, yeserday they were loose. So I cut the old bearings off and Rob pressed the new bearings on. Everything went back together in minutes. I'm probably crazy, but the Jeeps seems smoother and in a way tighter all around. I find this to be interesting. Last summer the whole idea of working on a rear axles was daunting. Today it takes longer to set the Jeep on stands than it does to pull the axles out. What once was almost frightening is now a simple matter. It apears that even an old fart like me can learn.
Hey Posi - Now you have me curious. What is the differance between the 72-75 front mount and the 76 -86 mount. Way back when I took the front off my '80 and recently took the front off the '75. Besides the lights being different, I can't recall them being different. Is it something minor?
