Just fill the gas tank is all-:eek: :D
Teach'n the 2 oldest granddaughters to drive a stick(19 and 15 years old).
[emoji106]
I remember the crazy look my 10 year old daughter gave me when she so the crank window hard door on my CJ for the first time - like, what??
Wooly
The ones you have are tough, don't rust and don't rattle. Nothin' wrong with that. Now for some milk crates. I've got to set up some of mine again. In my old CJ5 there was a system. Quail hunting got one set, big game got another, camping another set. It was a good system for a quick get away.
Busy 1/2 day on the CJ:
Re-routed the E-brake, I had the line outside the frame rails, moved them inside for some safety.
Found a gap in one of my rear spring bushings between the spring and the frame ears. Last time I put the bolt in I used a standard thread nut on a fine thread bolt. Felt tight, wasn't though. The springs are tight now.
Found where the flange on one of my cats. was touching the Transfer Case . Bent that out of the way.
Found where a long bolt was touching a header. Cut that shorter.
Tightened this and that.
Got out the power washer and washed the oil/grease off the underneath. Was afraid I was losing 2nd gear, it just wasn't feeling right. The CJ has had a small leak in the transfer case bottom pan. Tightened that up and topped off the Transmission . Almost 1.5 quarts! My goodness that is now on my maintenance list. The transmission is like new again. Goodness what's wrong with me?
Checked a number of "To Does" off the list.
My throttle bushing broke at the pedal.. No one in town with one so I Used a couple coins.. Drilled a hole in one then Dremel tooled a line to the hole and slid on cable and closed gap.. Works great!
Your doing a good job for not having done this before. The Scramblers really starting to come around. :chug:
Thanks Pete. I am nervous about putting things back together. I am betting that I will find hoses and wired that I did not label well enough. You know, I said "heck, I will know where that connects". Which is one reason I want to get this done. So I don't forget the little things.
Gonna try to hook the fuel lines up this weekend and replace the output shaft seal before putting the body on. Hopefully will do that work this weekend.
I am gonna need an army of friends to move the tub.
I wish I had the space to have both in the garage. Then I could do more in the evenings. Right now it is weekend time.
You'll be alright. There will be a surprise or two and maybe a "Oh Duh" moment but your well on your way. I'm going to pull the front clip off my CJ7 this weekend to make it easier to remove my old engine. I can't lift the engine high enough to get it out unless I go this route . Remember once your Scrambler is done we can have a weekend at Raush Creek. :chug:
You'll be alright. There will be a surprise or two and maybe a "Oh Duh" moment but your well on your way. I'm going to pull the front clip off my Cj7 this weekend to make it easier to remove my old engine. I can't lift the engine high enough to get it out unless I go this route . Remember once your Scrambler is done we can have a weekend at Raush Creek. :chug:
Sounds about right. Let's do it.
Just finished drilling my support plates and welding in my body mounts. Not super nice like what a lot of you guys do but it's a big improvement over what was there.
Wooly
What? I never heard of this before. Great. Thanks a lot! Now I have another item to put on my To-Do list...
:) I didn't do it by choice - both sides of the support crossmember had fatigue cracked where the body mount hole is so this seemed like the logical fix vs trying to remove the entire crossmember. But, I'm glad I can help with you list :)
Wooly
Dropped the Transfer Case and adapter and installed the gasket between tranny and the adapter. Replaced the adapter seal. Hopefully this greatly reduces the oil loss.
$35.00
  17.5%
