Replaced the leaking power steering return line. It was getting worn by the bolt for the steering gear knuckle. It was to the point that any fluid in the reservoir was just hitting the ground.
Used mine yesterday to jump-start my Granddaughters car at school.
Stripped, de-rusted, and painted more heater parts...
Cleaned up and painted the factory air cleaner assembly and used the Weber adapter to mount it. It runs way better now than with the tiny Weber air filter, even had to jet up the carb since it was going lean with the added airflow.
Boy she sure is clean and pretty
Sent from my toilet using Tapatalk
Replaced 3 rubber expansion plugs that my new client received from a so called professional auto service shop. Two of the 3 were leaking so I replaced all three with melling brass plugs (1.5”). They also snapped a motor mount bolt and left the broken end in the block. I was able to retrieve it.
AMC 360
AMC 360
So how did you get that busted bolt out anyway, Posi? was it a simple unscrew or did you have to perform magic?
Man that’s a beautiful engine
I got lucky on this one, there was enough sticking out. I used heat until it was red hot then removed the stud with a vise grip. When I'm not so lucky and there isn't anything sticking out I'll dish a washer, weld it on the stud, then weld a nut on the washer.
.....When I'm not so lucky and there isn't anything sticking out I'll dish a washer, weld it on the stud, then weld a nut on the washer.
Now, THATS a nugget worth remembering..... I know I’m late to the party, but that’s a great solution!!
Sent from my gas grille using Tapatalk
I really want to go to Colorado this year so I have been working on my rear disc conversion , lol nothing is the same size, I thought I was going to have to put my rotors on the rear of the axle flange so I ordered them with screw in studs..... surprise surprise Moser made the flanges so that the rotor slid right over how ever the hub center register is only 3.5 and the rotor is 3.75 so I can’t get it centered with out a spacer. Well I figured out that Moser actually pressed a spacer on the axle flange and it’s real hub dimension is 2.75 inches so I’m working on a spacer that will center the rotor and the wheel which is AMC 258 i6 / 4.2l inches and I have a slug of stainless to work with which is hard and slow to mill... I’m a newb with Limited skills tools and access to a really old lathe
Found a craigslist add for a AMC 360 long block with 110K miles running great when pulled. Came with 1 blown GM Turbo 400 tranny and another questionable condition, and a recently refurbished qt Transfer Case - all for $400!
So of course I jumped on it and figured I'd sell everything else besides the 360 since I didn't want any of it, and I'd be out close to even... Then I'd strip the running 360 down and build it back fresh and the way I wanted slowly...
Sweet deal - all good right?
Well, we got there and the 360 was actually a AMC 304 ... BIG numbers stamped on the side... Dude offered to drop it $100 for me (so $300 for all that) and I was tempted, but I've already got a AMC 304 if I just want to build one...
I'd like a nice clean 360 to slowly build how I want it and take my time, then do a weekend swap.
So back on the chase... Knew it was too good to be true, and 20 minutes away from my shop lol
Man that’s a bummer
Sent from the gas station using Tapatalk
found another one (360) - not as sweet of a deal, but sounds promising. Heading over after work to check it out. May have a new project soon... :cool:
Advertised as a 71 AMC 360 engine.
Missing flywheel, head bolts, and intake / exhaust...
$400.
Looking at a few goodies for it and I'm around $1300.00 in parts for it already. Not including hot tanking or professional bottom assembly... Oh well - jump in swimming right?
71, more power then later 360’s. 71 came with 285 HP (w/4bb) compared to the later 130/160HP engines. If it’s missing the intake I’m assuming the 4 bb is long gone.
Still checking into it but its mine now. Bit less complete than i was hoping for but got it for $300 and appears to be stock bore, clean crank surfaces cylinder walls etc... also has the dog leg ports on heads and better version casting numbers.
Better pictures tonight :chug:
Good on you! :chug:
    Best for votes
    on specific items
