I finally got to drive it again after two weeks :cool:
Just finished setting the timing after replacing the timing chain. Since i had plenty of day left i replaced the leaky axle seal and took her for a test drive.
Spike
I spent this afternoon using the CJ to transport bags of corn way back into the woods to my deer feeder. It's been raining here for two days, so only a Jeep or a mule was capable of getting through all the mud on the trail.
Spent the day 4wheeling with Tin Medic, Purple77cj7 and csuengr. And had a blast. It was a pretty tough trail I got hung up on the rocks a few times and bent my factory step on the right side up.I will be posting pics on my thread soon.
IOPort51 Now if it just had a cup holder.:D[/QUOTE said:
rookie mistake, all of that work and you forget to put a cup holder in.:banghead:
Sent from my C771 using Tapatalk 2
We can retrofit, we have the technology. and the motivation. I am thinking something with a gimbal.:cool:
Finally put my new engine and tranny in last night. I'm figuring about 6 more working hours before everything is back together and I can turn the key.
This morning I broke off a manifold bolt flush in the head !!! %^#%$&$ ME !!!
I've broken two drill bits and 1 easy out trying to get that damn grade 8 bolt out. First though I had to drill an 1 1/2 hole in my inner fender well to give me access to the damn thing. It was either that or pull the motor/Transmission I just put in....
Looks like I'm gonna have to drill it out and run a tap in it and hopefully clean up the threads....
DAMN DAMN DAMN DAMN....(sorry CJ) DARN DARN DARN DARN
If you broke off a grade 8 bolt holding the manifold, do you think that you just may have over torqued it ? just a little?:eek: Maybe?
I've broken two drill bits and 1 easy out trying to get that damn grade 8 bolt out. First though I had to drill an 1 1/2 hole in my inner fender well to give me access to the damn thing. It was either that or pull the motor/trans I just put in....
:)Hummm, should I use my 3/4 or 1/2 inch impact? :eek: (LOL)
:D
Funny IOPort51 !! .... Next week I'll laugh. today I'm just pissed at myself
I am doubting the quality of the Ace hardware grade 8 section.
These bolts were used on the 360 I just pulled out, but apparently the heads are NOT drilled as deeply as the former heads......and I didnt check the available depth. I torqued to the specified 15 lbs, and still could see a hairline gap between the manifold and the bolt head. Normally I would have STOPPED and backed it off, but I thought it was just pulling the manifold in. I couldnt have gone more than 18-20 lbs before it twisted off.
I was a bit suprised. The older-wiser me didnt throw anything or even swear (that much)... I guess age has had an effect on my temper!! LOL
:D
I couldnt fit an impact in there but the 3 ft pipe on the ratched seemed to provide enough leverage:eek:
(same bar I use to torque my spark plugs)
