Wiped the blood off the fender were a 2ft 1/2 inch ratchet suddenly broke loose a stuck bolt plugging an air feed hole. My hand kept moving at high rate, into one of the horn edges. It'll happen again!
Sorry for your fortune but we love carnage!
Angle grinder 2012
Ouch thats going to leave a mark. This is what did you do to your Jeep today not what did your Jeep do to you today.
Ran my first full tank of gas in the new engine...
20 gallons of gas / 200 miles.... AARG!!! Looking for a new carb!!
I'm negating everything my green neighbor is "trying" to do by driving a Prius
Finished up bedliner and ordered a new tailgate rubber. Body stuff pretty much done. Now save pennies for engine!
To Germy, What type of bedliner product did you use and did it work well or a P.I.T.A. to use? I have a $300 quote frome Line-X to do underside and $400 more to do passenger compartment...
thanks
I would have it sprayed professionally initially. You will have trouble mantaining the splatter affect while trying to cover. Their :dung: is heavier..and I'm sure better primer. Mine was a touch up, just wanted it back to black. My only warning to you is to talk to them about taping off and what you don't want lined. My po just had them spray everything. Fing mess.
Edit. Did a panel over self etching primer. Held can far back and do light coats, like 5. I let it dry between for like a half hour. Looks great. So up to you;)
Got my small bearing spindles and Ford hubs and rotors from UPS today.:)
I'm one step closed to getting my Dana 44 ready for the jeep this winter.
Now I just need the wheel bearings and seals, and ball joints and I'm ready to start cutting the housing down.:D
Hey old dog, are you doing a write up with part numbers and measurements on thos build? :drool: i know theres a few out there, just wondering...
Jr
Ya. If he got one of the those electric jobs you should let him know that 50% of electricity in this country is produced by coal.
Im going to get some "powered by coal" bumper stickers and put them on electric cars.
Congrats on getting the bugs worked out on your Jeep.
Jr
I could, but it probably won't happen till Jan. or so.
My money tree didn't produce much this year.:D
Slid back the instrument panel and pulled the speedo; began John Strenk's troubleshooting checklist. Temp Gauge OK through step 4. Tomorrow dropping the fuel tank to begin that onerous task. Wiring beneath the dash a bird's nest with lots of orphaned wire runs.
Fixed the heater blower motor.
Soaked fasteners down with PB-Blaster getting ready for tub removal and tear down. Sprayed a boat load of Sea Foam down Carb, cranked over with starter to suck into carb and manifold etc. (37 degrees F, rainy+drizzling out) B4 I start disconnecting stuff. She started right up, all I did was give the pedal a couple of pumps w/hand standing next to her to open up plate....funny, wasn't trying to start her! Never figured she would with all the carb cleaner I just dumped down her throat! I figure she is just teasing me....:cool:
How do I? Oil seal
    Best for votes
    on specific items
