Still working as we speak but wife is taking a test for school and I need to cut... oil shield from the original intake, does not fit the Edelbrock intake with the EGR provision.
I'm going to cut the section off that protects the PCV valve and then bolt them on separately.
Welded some brackets on my roll cage to mount my CB. Stupid flux core :dung: pops so much. Had a piece land in the seat I was sitting in and did a number on my leg. Ran the wires for the CB and a Blue Sea dual USB charging port for my cell phone. Need to get a proper power distribution block.
Hedge, is that can plastic? I have had conventional plastic cans leak. Not sure if you want to write that off as one that got through quality control. I have a couple of steel Blitz cans that are many years old with no leaks yet but do replace the cap gaskets every now and then.
Nope, mine is a one of the high quality steel Wavian cans. Bought a nice little green 10 liter can to replace the 20 liter can today. The 10 fits the holder wonderfully, it's nice and short while being easier to handle. Unfortunately it is the very same price as the 20.
I did find out something interesting though. Wavian has a 2 year guarantee. Maybe I'll get a new can.
While I prefer a steel can, the plastic military cans have a great reputation for toughness. Even more interesting, according to the seller (I also got a plastic water can), a civilian can't legally buy the modern plastic military Jerry cans. Why????????? Who knows!
Well here goes ..I've had a decent crack at it this weekend
Alternator in.
Started pulling Transfer Case apart ... unsealed gaskets everywhere.. distorted Transfer Case cover plate ..
roller bearings worn and forcing cones worn.. so badly on one that checking sideways play the cage fell off and all the conical rollers fell out .. parts order to replace them
So to sum up .. shafts out handbrake drum off ..speedo housing off .. holes opened in Transfer Case .. parts gears and pieces littered under the jeep in spercific order and I have made a song.
Bought a jeep... and it leaks .. dribbles everywhere ..oil seals bugger and bearings showing heaps of wear ...lol
When repairing a mess like that you absolutely know you've done a good thing. There are few things worse than doing a job like the one you are engaged in not knowing if you did any good at all. You know without a doubt that the work was necessary.
Well hacked up and got it all on.
Waiting an hour to torque them the rest of the way down.
Yeap very important job .. I've decided to pull all the seals that the previous owner has changed .. he didn't clean up every surface so it all leaks..
checked all the gears and splines they have a tiny amount of wear but it's not bad and well within tolerances.
Considering the state of the roller bearings I'm surprised more wear and damage wasn't done
Lowered the Transmission in yesterday, through the engine bay rather than having to tip the Jeep over trying to make enough clearance for the T-18 and Transmission jack. Hope to get the engine in today.
Finished taking all the stuff off the old beatup YJ windshield frame to clean and paint getting it ready to stick on the clean YJ WS frame and I have a question.... Anyone know what these holes are for? There are two, one either side, toward the inside upper corners above the glass. Both had hole plugs in them...... Any ideas??
Worked on my GM Turbo 400 . About 80% reassembled, still need to install pump and valve body.
PO maybe thought that was a great place to hang a mirror?
I was thinking water inlet, so years from now it will rust and virtually weld itself to the tub...? No?
Wheel bearing replacement for the 5th time. Hopefully I bent the washer well enough that the inner nut will stop loosening
LOL - While it will serve that purpose very well, both windshield frames had the same holes and plugs..... didn't look homemade......
I think I know what them holes are for .. you stick a rod between the to hang a privacy curtain while getting down in the back seat lol
Or maybe 007s right .. it's a water jacket to run hot water through to defrost the windscreen which will rust to the tub
Gettin down in the back seat of a CJ......... LOL. Maybe for a couple midgets.......
Lol
Got my tubes cut off my skid plate so I could make a 2.5 inch drop skid to clear my enormous NV4500, motorcycle jack is extremely handy by the way, once I get the Transmission mount figured out I can grind stuff nice an smooth.
Sprayed some bedliner on my tuffy box today. Emptied the entire can. Hopefully its enough to stop it from getting all scratched up. :)
gert,
Looks 1/4"?
What was your process of matching the frame threaded holes to your skid plate holes? I know folks use different methods just curious as to yours.
How do I? Oil seal
$150.00
  75.0%
