He wasnt fast enough to poop on you as you were going by
Actually I knocked the snot out of him. He was inside the grill area, in the far lower passenger side between grill and radiator.
Not done today but in the last month, oil and grease service, valve cover gasket replacement. Doors and windows off for summer. Continued:cj7: smiles per mile.
Mine is in the shop. I don't have time to fix her as it's busy season at work. So I have a shop doing some diagnostics and repairs
I gave the Jeep a very good cleaning today. A good wash this morning on the outside and engine bay. Then this afternoon in the garage with the ac cooling things I used a bucket with many refills and a small towel and wiped down most of the interior and seats to get the 4 days of Arkansas trail dust removed. Very dry and dusty there.
I finally solved the squeaking coming from the rear at 20 mph +. I did a brake job months ago and didn’t install the handbrake components correctly. Grrr!
At least the parts weren’t scattered along the road.
Dude, tell me about it. Or end up with a locked up wheel in the worst case! LOL
I overcompensated the adjustments at the cable and at the self adjusting detent wheel.
Looks like a good solid fix. There probably isn’t a way to get some fender washers behind the skin.
What he did was probably the best fix. If it was a show Jeep I'd say it could have been flush welded and finished in plastic filler (Bondo) then painted. But nice work all the same
Don’t trash that cigarette lighter and socket if it’s CJ original.
Greased the front end and drive shafts and checked the Transfer Case and Transmission fluids. Also checked bolts on ujoints and front hubs. The Jeep definitely took some abuse up in Hot Springs ORV, but seems to be ready for the next adventure. This one won’t be as hard off road. More of a road distance type of trip. Heat abuse for Jeep and driver.
