What is this pipe?
What is this pipe?
1984 CJ7
Portland
1984 CJ-7, 258 (rebuilt), 5 speed (rebuilt), softtop, Goodyear DuraTrac's
It is just part of your emission system I wouldn't worry to much about it.
It goes from your air cleaner to you catalitic converter, however I am not sure if it circulates clean air to the cat or crappy air from the cat back into the engine either way I lost mine years ago :rolleyes:
That's a "anti backfire" valve for the air injection system. The air injection system forced clean air into the exahust to help reduce emissions via an engine driven air pump-which may be long gone. More O2, less CO emissions.
The bell shaped piece is where a poppet valve resides. It only allows flow-one way in case of an exhaust backfire.
If you do not have to meet emissions requirements-LOSE it.
Perfect, I won't worry about it! thanks agian!!
Well, i would remove it but i have to pass DEQ so I guess i will keep it.
