What throwout bearing and fork to use?
kovacjr
NJ
02 Silverado Z71 5.3
72 CJ5 304, 3sp, 2.5" lift, 33x12.5
I have done a 360 swap along with a ford T-18 . I have the short bellhousing to match up with the Transmission to the AMC. Question is I had a bearing that came with the clutch. the clutch is the right one for the ford to amc. My orignal fork was a clip in bearing and that was asked when I bought the clutch Problem is the bearing is now shot and the fork is loose, hard to shift. Fork now has lots of vertical play. I had bought a new fork when I was converting but it was for a round GM style bearing. Im luckey to have 200 miles since it was reassembled. It seems as though the fork is still just catching a little bit with the the pedal released.
SO how do I figure out what to use for the correct bearing and fork?
