Wiper Motor HELP PLEASE
tonkatrucksryan
Waldorf, MD
1975 CJ5 w 4.2 258.
2004 TJ Rubi
2011 Toyota Tundra
Well I have been replacing the dash. I replaced the wiper motor switch and the wiper motor and nothing works. Im at a loss. I hope someone can give me some pointers. Thank you so much. :(
Start with the fuse, I know it sounds silly. It's a simple system
Thanks I already checked the fuse. All good. Still banging my head against the walls
My Cj also has a painless wiring harness that the op put in. Because of the glass tub I think there might be a grounding problem. Everything else works.
this is a very real possibility, as I recall the WW grounds through the motor housing. try running a wire from battery neg. to the WW motor mounting bolt.:D
You should be able to diagnose your problem in minutes with a meter and the diagram I linked to.
Do you have a meter and know how to use it?
I have a meter but it has been a long time since I used it. Not sure what setting to put it on. I did take a test light to it and there is power leaving the switch. ugh Hope your feeling better CJ
I just googled "how to use a volt meter" and there are about 5 ka-zillion you tube videos on the subject.:D
Thank you IOport51 I ran a wire last night to the housing and you were def right. I crapped my pants when it worked . I will hard wire everything tonight. Thank you. :chug:
