1979 CJ-7 V-8 Engine
keepulookin
Earlier this evening I was looking at kits to overhaul the carburetor on my '79 CJ7 . I went to jeep4x4center.com and did a live chat with a salesperson that gave me a link to a carburetor kit for a 6 cylinder. I have an 8 cylinder and he said it wasn't possible given the CJ-7's VIN. The previous owner told me that it has the original engine in it. It is in fact a V-8. There are 8 spark plugs that are running to the distributor cap.
I began looking for any identifying marks on the engine itself, aside from the order firing number on the top of the engine, but found none. I'm not really sure which carb kit I should get now as the salesperson told me he couldn't help me without the actual engine model number stamped on the engine. He said if I do indeed have an 8 cylinder, the 6 cylinder carb kit wouldn't work.
I've looked on top of the block, on the sides, on the valve covers....where else can I look? Or if anyone else out there has a '79 CJ-7 with an 8 cylinder able to steer me to the right kit...
edit: the part number on the side of the carburetor is 7043792 and it's a GM 2 Jet Rochester.
