Cj5 i6-258cid
depends on who's T-18 you use. check out the Novak adapters page for all the possibilities.
Novak Jeep Conversions - Home
It looks like it has been updated, may have to spend some time there myself.:D
Hello,
I'm brand new to the Jeep forum. Thanks for having me. I have recently purchased a '76 CJ5 258 I6 with the old 3 speed tranny.(I assume T150). Does the T18 have the same splines and bolt pattern to connect to the I6 and Transfer case?
Thanks!!
I, too, have joined the Jeepers with the recent "adoption" of a 76 CJ5 I6 AMC 258 i6 / 4.2l 3 speed!
So, hopefully we'll be friends.
I have a rattle noise coming from my T-150 's 3rd gear when I let off the gas and the momentum of the jeep catches up to the tranny/engine speed. I've tried to duplicate the rattle in the other two gears and it's only 3rd. So it's not a U-joint or throw out bearing.
It sounds like a tuning fork getting pinged around. So..... Maybe a shift fork?
Thanks for any ideas and thoughts.
You would need a T-18 that bolts to a Dana 20 . The rear output bearing retainer has the "texas" pattern to fit your Transfer Case .
The bellhousing is different I think. The splines are no big deal as can but the proper clutch plate to match the splines. The Jeep versions are 1-1/8" and the Ford T18's have a 1-1/16". You also need a special pilot bushing to fit the smaller and shorter nose of the Ford T18 input shaft. This is assuming you will be using a Ford T18 as opposed to a tough to find Jeep T18.
Also remember the T18 is longer which changes your tcase shift linkage.
