Build Thread CJ7 restoration in progress- Advice please
bullseye
So this is how he did and will do the front rear patches. He put a bend in the end of the 16g steel and cut the patch to size in pic 1 2 3. The patch is bolted in place using factory bolts.
He then hammered the bend forward and flush to the side wall and welded across the top.
That is his welder in pic 4.
Pic 5 shows the new found rot where the seat belt bolt used to be.
A side note: In pic 5 you can see the bolt I said I needed to drill out in the lower left... I'm glad I thought that one through. That is the bottom of the bolt of the body mount. The head is under the Jeep. I thought I had knocked the head off the top...
